dlela61
#1 Posted : Tuesday, April 14, 2009 1:17:10 PM(UTC)
dlela61
My dryer makes a scraping noise when it tumbles. Clothes get dry but the tumbler is hard to turn when trying to turn it by hand. How do I remove cover to see what it might be? :confused:
sidfink43
#2 Posted : Tuesday, April 14, 2009 3:57:02 PM(UTC)
sidfink43
Open the door and look for two phillips head screws going into the top of the door frame. Removing these will allow you to "pop" up the top and slide it off. There are then two hex head screws holding the front panel. Remove these and you now have access to the interior of the machine.
Reach is to release tension pulley on the belt, and then you can remove the drum to determine your problem. Look for a problem with the rear bearing or the rollers.
Click on your model number to get a set of exploded views for your machine and to order the parts.
Good luck, and post how it turns out.
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Sub-Zero new model makes loud noise (Refrigerator & Freezer Repair)
by Guest 5/3/2024 7:49:55 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
Kenmore 110.47566601 makes loud spin noise (Washer Repair)
by Guest 4/6/2024 7:42:40 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
Speed Queen Washer makes random squeaking noise (Washer Repair)
by Guest 2/10/2024 7:29:00 AM(UTC)
Control panel goes dark and loud clicking noise (Refrigerator & Freezer Repair)
by Guest 2/6/2024 12:57:10 PM(UTC)
Slow agitation and spin with clicking noise in bottom end of machine (Washer Repair)
by Guest 1/13/2024 12:19:08 AM(UTC)
Noise during rotation of dryer drum (Dryer Repair)
by Guest 1/5/2024 11:22:05 AM(UTC)
LG dishwasher loud clicking noise after cycle completes (Dishwasher Repair)
by Guest 10/29/2023 6:43:16 AM(UTC)
Samsung Front Loading Washer - Noises Even When Manually Spun (Washer Repair)
by Guest 10/18/2023 3:20:35 PM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
