I have a Kitchenaid Superba Refrigerator manufactured 08/03. The water dispenser takes a long time to dispense water through the door. The water line on the back of the unit is not kinked, the water filter has been changed, and the water line has been "flushed"-held a cup to the dispenser for 2 minutes to remove any air bubbles.. What else can I check or what may need to be replaced? This has been going on for quit a while now and it just seems to get slower and slower by the day. Thanks for any input. I appreciate it... :)
Also, our ice maker has just stopped working. We really don't know why.. Can this be the issue or what can we check for the ice maker not working? As stated before, water filter has been changed and no kinks in water lines.
Looks like there is not enough pressure in the water line.
Check the water supply line. It has a screen filter in the end of it where it hook to the water inlet valve. Check the pressure there when you have it disconnected. Disconnect it where it comes out of the water inlet valve and try the water again.
Ok, I am going to try that tonight. What if that does not help? What else can I look for? This is so I can go ahead and look while I'm already there. Also, do you think that may be the reason our ice maker is not working?
Lets do one thing at a time. Post the results.
Originally Posted by: Gene Lets do one thing at a time. Post the results.
Gene. <img src="C:\Documents and Settings\Misti Wade\My Documents\Belt install"></img>
Originally Posted by: Frank / APP Team <img src="C:\Documents and Settings\Misti Wade\My Documents\Belt install"></img> Please ignore last post. My mistake while trying something.
