kelmattandrandy
#1 Posted : Sunday, April 12, 2009 6:01:54 PM(UTC)
kelmattandrandy
I have a Kitchenaid Superba Refrigerator manufactured 08/03. The water dispenser takes a long time to dispense water through the door. The water line on the back of the unit is not kinked, the water filter has been changed, and the water line has been "flushed"-held a cup to the dispenser for 2 minutes to remove any air bubbles.. What else can I check or what may need to be replaced? This has been going on for quit a while now and it just seems to get slower and slower by the day. Thanks for any input. I appreciate it... :)
Also, our ice maker has just stopped working. We really don't know why.. Can this be the issue or what can we check for the ice maker not working? As stated before, water filter has been changed and no kinks in water lines.
#2 Posted : Monday, April 13, 2009 4:49:55 PM(UTC)
Looks like there is not enough pressure in the water line.
woodchuckie
#3 Posted : Monday, April 13, 2009 7:45:12 PM(UTC)
woodchuckie
Check the water supply line. It has a screen filter in the end of it where it hook to the water inlet valve. Check the pressure there when you have it disconnected. Disconnect it where it comes out of the water inlet valve and try the water again.
kelmattandrandy
#4 Posted : Tuesday, April 28, 2009 10:32:02 AM(UTC)
kelmattandrandy
Ok, I am going to try that tonight. What if that does not help? What else can I look for? This is so I can go ahead and look while I'm already there. Also, do you think that may be the reason our ice maker is not working?
#5 Posted : Tuesday, April 28, 2009 1:15:54 PM(UTC)
Lets do one thing at a time. Post the results.
Frank / APP Team
#6 Posted : Friday, August 28, 2009 9:32:39 AM(UTC)
Frank / APP Team
<img src="C:\Documents and Settings\Misti Wade\My Documents\Belt install"></img>
Frank / APP Team
#7 Posted : Friday, August 28, 2009 9:42:18 AM(UTC)
Frank / APP Team
Please ignore last post. My mistake while trying something.
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Kitchenaid Refrigerator Issues With Dispensing Water (Refrigerator & Freezer Repair)
by Guest 10/2/2023 1:29:10 PM(UTC)
Kitchenaid Refrigerator Help Needed (Refrigerator & Freezer Repair)
by Guest 5/31/2022 3:40:02 PM(UTC)
KFIS29BBMS03 KitchenAid Refrigerator freezer only gets to 17 degrees, Fridge seems okay at 38 (Refrigerator & Freezer Repair)
by JCohen8008 6/28/2021 8:00:28 AM(UTC)
KSRS25IKBL03 KitchenAid Refrigerator stopped making ice - optics have been replaced (Refrigerator & Freezer Repair)
by Jfranks 12/5/2020 2:47:58 PM(UTC)
Kitchenaid refrigerator problems (Refrigerator & Freezer Repair)
by Kendug 8/12/2020 7:40:47 AM(UTC)
Help! Tech sheet lost for Kitchenaid refrigerator (Refrigerator & Freezer Repair)
by DANDKB 4/24/2020 11:38:19 PM(UTC)
Kitchenaid Refrigerator KSSSQTB00 (Refrigerator & Freezer Repair)
by Spearcatcher 12/18/2018 1:39:56 PM(UTC)
KitchenAid refrigerator ice chute replacement (Refrigerator & Freezer Repair)
by harrychou25 7/11/2018 1:44:23 AM(UTC)
kitchenaid refrigerator diagnostic mode (Refrigerator & Freezer Repair)
by oldfartsexpress 5/24/2018 5:29:43 PM(UTC)
Hinge repair on KitchenAid Refrigerator (KSSC42QTS00) (Refrigerator & Freezer Repair)
by clivedaw 1/5/2018 12:47:03 AM(UTC)
KitchenAid refrigerator did not work (Refrigerator & Freezer Repair)
by hhh123456 6/14/2017 1:58:45 AM(UTC)
Kitchenaid Refrigerator ice maker (Refrigerator & Freezer Repair)
by southerncooker7173 8/25/2016 11:01:00 AM(UTC)
KitchenAid refrigerator KSSC48QTS00 not dispensing water or producing ice (Refrigerator & Freezer Repair)
by Koolman10 6/25/2016 11:40:22 AM(UTC)
