A few days ago, I noticed that the water in door was a very small stream. The ice cubes coming from the ice maker are perfect in shape, however, they are hollow, and they are smaller! The ice cubes are clumping up in the bin! I checked the water line and it seems to be fine. Please advise!
I changed the filter in my Kitchen Aid fridge. The light was not blinking, so I didn't think it needed to be replaced. This fixed the water in the door and the ice maker. I forgot that when the filter needs replacing, it stops running water through it, that's why the water in the door was a very small stream. :D
