Andrew DeLeon
#1 Posted : 16 years ago
Andrew DeLeon
Only a trickle of water comes out of the dispenser. Ice cube maker is working.
woodchuckie
#2 Posted : 16 years ago
woodchuckie
Disconnect the water line coming out of the water inlet valve on the back of the fridge and see if you only get a trickle there. If so the valve may be bad. If it's ok there disconnect it at the bottom of the freezer door and try the water if it's ok there it may be freezing in the freezer door.
Water dispenser not working. (Refrigerator & Freezer Repair)
by DVDA247365 11 years ago
by Lizg23 14 years ago
water dispenser not working. (Refrigerator & Freezer Repair)
by food 15 years ago
