Andrew DeLeon
#1 Posted : Sunday, April 12, 2009 10:43:00 AM(UTC)
Andrew DeLeon
Only a trickle of water comes out of the dispenser. Ice cube maker is working.
woodchuckie
#2 Posted : Sunday, April 12, 2009 2:32:56 PM(UTC)
woodchuckie
Disconnect the water line coming out of the water inlet valve on the back of the fridge and see if you only get a trickle there. If so the valve may be bad. If it's ok there disconnect it at the bottom of the freezer door and try the water if it's ok there it may be freezing in the freezer door.
Water dispenser not working. (Refrigerator & Freezer Repair)
by DVDA247365 11/12/2013 11:44:19 AM(UTC)
by Lizg23 7/13/2011 12:52:35 PM(UTC)
water dispenser not working. (Refrigerator & Freezer Repair)
by food 3/5/2010 1:23:26 PM(UTC)
