4truckingup
#1 Posted : Monday, September 5, 2011 9:12:20 AM(UTC)
4truckingup
my cabrio does like many i have read about here. start it. it begins to fill then stops with a f1 error code. i see this is typically a control board. i call whirlpool they tell me that my model and serial combination is not on the recall and not known to have have a control board issue. they steer me to a water flow problem. is this possible? serial # cu1071342 model wtw6600sw2
sidfink43
#2 Posted : Monday, September 5, 2011 5:11:02 PM(UTC)
sidfink43
With this model anything can happen. There do seem to be a lot of posts here about control board problems. The error code is for a control board problem. Don't know why Whirlpool would say check the water.
I would replace the control unit, but who knows, I mean Whirlpool apparently doesn't even trust their own diagnostics.
Replaced both Membrane Front Panel and Control Board - Still getting F1 Code (Oven Repair (including Ranges and Cooktops))
by StanJ55 3/7/2017 7:52:59 AM(UTC)
Maytag oven with F1 code (Oven Repair (including Ranges and Cooktops))
by Bwhite 6/28/2015 10:46:23 AM(UTC)
Whirlpool Bravo Washer Has F1 Code (Washer Repair)
by stargazer4591 4/7/2015 7:42:35 AM(UTC)
My Frigidaire Electric Range is showing F1 Code. (Oven Repair (including Ranges and Cooktops))
by smieri6 7/20/2013 9:45:09 PM(UTC)
Oven: F1 code (Oven Repair (including Ranges and Cooktops))
by a029342 7/1/2013 5:44:23 AM(UTC)
Amana F1 Code (Oven Repair (including Ranges and Cooktops))
by alongwalk 3/17/2013 1:59:18 PM(UTC)
Advantium 240 Above Range F1 Code (Microwave Repair)
by cooldaddyo 1/20/2013 7:35:58 AM(UTC)
LG / F1 code (Oven Repair (including Ranges and Cooktops))
by pipeliner11 12/1/2012 5:07:05 AM(UTC)
Maytag epic z F1 code, Ive replaced 2-ccu (Washer Repair)
by 84capri 6/26/2012 10:49:30 AM(UTC)
Kenmore Range E2F1 code...please help (Oven Repair (including Ranges and Cooktops))
by tferraro 1/9/2012 7:36:49 AM(UTC)
Kenmore Oasis Washer F1 code (Washer Repair)
by sofedup 1/2/2012 8:18:51 AM(UTC)
Cabrio Washer Showing F1 Code (Washer Repair)
by gsmith 8/9/2011 8:00:57 AM(UTC)
F1 code appears (Washer Repair)
by slcohen61 5/30/2011 10:03:49 AM(UTC)
by jcorsent 4/19/2011 8:59:39 AM(UTC)
Water valve noise and F1 code (Washer Repair)
by dayb2000 3/7/2011 10:02:38 AM(UTC)
