the dryer isnt heating and it the timer keeps on going unless the door is open
I think you are missing the first 3 digits from the Model Number. I cannot find any info on it.
Is it gas or electric? If electric try flipping the breakers off/on slowly a couple times. Better yet measure the voltage at the plug with a meter. Sometimes you can loose half the line without tripping the breaker. The heater needs the full 240 volts but the timer and motor run off half the line, 120 volts. Next possibles are the thermal fuse and the heater. Both best checked with a meter.
It is normal for many dries to power the timer till it hits the off position. |
THIS FORUM IS DEAD!!!!!!! |
oh yes. '110.' are the first three numbers and the dryer is electric.
