dukejd
#1 Posted : Friday, March 27, 2009 8:49:41 AM(UTC)
dukejd
I have check the door switch, thermal fuse, push to start button and all look okay. What I did find has me stumped as I cant seem to find it in the APP.com website. There is what looks like a thermal snap switch located just below the thermal fuse on the dryer exhaust box. Its a little different from the hitemp snapswitch on the element in that it has the two red wires that are closed and it also has two purple wires that are open. Can anyone tell me what that switch is and if it is correct. one more thing if it is correct is the timer the next best guess as to the problem.
dukejd
#2 Posted : Friday, March 27, 2009 10:28:24 AM(UTC)
dukejd
I did find that it was the thermastat. so I doubt that is the issue. Will I get a closed loop through the safety circuit if the motor start switch is bad?
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
