Hey everyone! Thanks in advance for any help you can give.
I have a (about) 3 year old frigidaire dryer that hasnt had any heat for about the last year. This model has 2 bigger wires going to a relay on the back of the control board that runs the heater. I originally wired my own switch and used that to get some heat and anytime the switch is on, the heater heats up good and hot.
I had thought that this problem was caused by a bad control board, so that was replaced recently. After replacement I ran some clothes through it, stuck my hand in there after it was running for a few mins and it was warm!
So...good to go right? Nope. =(. The heat hasnt come on since.
I have since ohmed out the 2 temp sensors that are right next to eachother, both read 0ohms. I have ohmed the heating element and get 12 ohms. I have taken it apart again and verified that the heater will activate if switched manually.
So...my questions are : What else could cause this? Did i have a damaged control board and damage my new one already due to another problem? Is there any other sensor, thermal limiter or ?? that could be causing this?
I am a auto tech by trade, so I am very lost in the world of appliances...help!!
Thanks all! Adam
Ok, update already... I checked my thermister. I had no clue there was another sensor until I just looked at the wiring diagram again.
Anyways, i got 12kohms @ room temp (65 or so). My tech sheet shows 50kohm as a spec.
Is this far enough out to cause it? What temp does the tech sheet refer to?
Thank you! Got it and installed today...perfect!!
For the record, the new thermister was 50kohms @ room temperature. I used a potentiometer in place of the thermister to verify this, just adjust the pot to your temp spec and see if the heat comes on!
Thank Gene!
You are welcome. I'm glad you were able to fix it.
