agarberg
#1 Posted : Wednesday, March 25, 2009 2:45:22 PM(UTC)
agarberg
Hey everyone! Thanks in advance for any help you can give.
I have a (about) 3 year old frigidaire dryer that hasnt had any heat for about the last year. This model has 2 bigger wires going to a relay on the back of the control board that runs the heater. I originally wired my own switch and used that to get some heat and anytime the switch is on, the heater heats up good and hot.
I had thought that this problem was caused by a bad control board, so that was replaced recently. After replacement I ran some clothes through it, stuck my hand in there after it was running for a few mins and it was warm!
So...good to go right? Nope. =(. The heat hasnt come on since.
I have since ohmed out the 2 temp sensors that are right next to eachother, both read 0ohms. I have ohmed the heating element and get 12 ohms. I have taken it apart again and verified that the heater will activate if switched manually.
So...my questions are : What else could cause this? Did i have a damaged control board and damage my new one already due to another problem? Is there any other sensor, thermal limiter or ?? that could be causing this?
I am a auto tech by trade, so I am very lost in the world of appliances...help!!
Thanks all!
Adam
agarberg
#2 Posted : Wednesday, March 25, 2009 4:42:40 PM(UTC)
agarberg
Ok, update already...
I checked my thermister. I had no clue there was another sensor until I just looked at the wiring diagram again.
Anyways, i got 12kohms @ room temp (65 or so). My tech sheet shows 50kohm as a spec.
Is this far enough out to cause it? What temp does the tech sheet refer to?
#3 Posted : Wednesday, March 25, 2009 5:03:57 PM(UTC)
The thermistor is the culprit.
- The part number for the thermistor is AP3866842
Here are the break down diagrams and Replacement parts for FRG GLEQ2152ES0 | AppliancePartsPros.com
agarberg
#4 Posted : Monday, March 30, 2009 8:11:07 PM(UTC)
agarberg
Thank you! Got it and installed today...perfect!!
For the record, the new thermister was 50kohms @ room temperature.
I used a potentiometer in place of the thermister to verify this, just adjust the pot to your temp spec and see if the heat comes on!
Thank Gene!
#5 Posted : Tuesday, March 31, 2009 10:58:59 AM(UTC)
You are welcome. I'm glad you were able to fix it.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
