H2o dispenser not working. Solenoid is working, have water into filter, dont think its coming out of filter. Filter has been changed. Ice maker is fine.
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does try a hair dryer blowing where the water line is at the dispenser for a few minutes.
