The water dispensing unit is intermittently sticking in the open position. This happens about every 10 to 20 uses. When this happens, the water stays on for about 10 seconds before it shuts off.
I have read in forums that it could be the water valve, the paddle unit, the microswitch or the main control board. From what I have read, a bad water valve seems to cause the water dispenser to turn on by itself, which is not what is happening. I am unsure which part would most likely to be casing this problem.
