Upright, frost-free Frigidaire freezer. Is there any maintenance I need to be performing? I removed the base panel see if coils needed to be cleaned. I don't see any coils.
Originally Posted by: Jhorn49168 Upright, frost-free Frigidaire freezer. Is there any maintenance I need to be performing? I removed the base panel see if coils needed to be cleaned. I don't see any coils. J, That unit has a "static" condenser, it is located on the back of the cabinet. It should be checked and carefully cleaned, occasionally(every couple of years). Other than that, your all right. :) :) :)
