compact, or combo unit, which the washer wont spin or drain. wash, agitation cycle works fine. any idea? Thanks
This is a Frigidaire made machine sold under the GE label.
You will want to check out the lid switch, that sounds like your problem. If it is ok the timer could be the problem, since this model has an electric pump and it sounds like power is not getting to the motor or the pump.
lid switch fine; timer works on fill, and aggitate; there is power to pump at connector. motor does not hum or anything in spincycle, but does work on aggitate. thanks
