tagm
#1 Posted : Tuesday, November 8, 2011 6:30:08 PM(UTC)
tagm
compact, or combo unit, which the washer wont spin or drain. wash, agitation cycle works fine. any idea?
sidfink43
#2 Posted : Wednesday, November 9, 2011 5:29:32 PM(UTC)
sidfink43
This is a Frigidaire made machine sold under the GE label.
You will want to check out the lid switch, that sounds like your problem. If it is ok the timer could be the problem, since this model has an electric pump and it sounds like power is not getting to the motor or the pump.
tagm
#3 Posted : Thursday, November 10, 2011 1:14:19 PM(UTC)
tagm
lid switch fine; timer works on fill, and aggitate; there is power to pump at connector. motor does not hum or anything in spincycle, but does work on aggitate.
thanks
Maintenance Man (Oven Repair (including Ranges and Cooktops))
by MAINTENANCE MAN 10/26/2009 12:53:48 PM(UTC)
