John R
#1 Posted : 16 years ago
John R
freezer not producing ice..code in freezer blinking red twice
John R
#2 Posted : 16 years ago
John R
no, it was part of it
kayakcrzy
#3 Posted : 16 years ago
kayakcrzy
My boy Johnny, here we go! Open the freezer door, and flip open the cover to view the icemaker. Now on top right hand side is a black hose, squeeze it, if you can, all is cool. If it is hard, it is frozen, and you need to get the blow dryer out and thaw it out, and replace the water valve, because a little bit of water is sneaking by, and freezing up. The water valve part # is 4389177. If all is well there, then I want you to look at the icemaker, and the fingers that knock the ice out, they should be looking at you, just peering over the horizon of the icemaker. If not, you need a new Motor module. You would have to remove the icemaker, by taking out the four 1/4 inch screws, that hold it in place, and then slide it forward, and unplug the harness, and then remove the 3 phillips head screws on each corner but one, and remove the motor module, and replace it. The part # is 8201515. If all is well there. Then you need to replace the emitter kit. That is the blinking light, and the other piece on the other side. Both pieces are held in by 3 phillip head screws, then pull the assemblys, out, and unplug the and replace the boards. They are both in the emitter kit. Part # is 4389102 Tom
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 10 months ago
Crosley, model: GS24Y8DV, side by side Refrigerator/Freezer. (Refrigerator & Freezer Repair)
by AeroncaChief 2 years ago
Kenmore Elite side by side refrigerator (Refrigerator & Freezer Repair)
by jfortner 3 years ago
Just bought new side by side refrigerator but doesn't get cold enough (Refrigerator & Freezer Repair)
by Hotlynx16 3 years ago
Admiral side by side refrigerator external drip drain tray (Appliance Parts)
by Paul Bridges 4 years ago
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5 years ago
GE Profile Side by Side Refrigerator Model ESS25XGMB (2001) not cooling (Refrigerator & Freezer Repair)
by boxer 6 years ago
Kenmore side by side refrigerator keep running (Refrigerator & Freezer Repair)
by Xmwwang 6 years ago
side by side refrigerator started clicking and humming (Refrigerator & Freezer Repair)
by mjkneiser 7 years ago
GE side by side refrigerator freezer not cooling (Refrigerator & Freezer Repair)
by ReddogRudy 7 years ago
Side by side refrigerator keeps turning on and off (Refrigerator & Freezer Repair)
by Rasenganguy 8 years ago
Side by side refrigerator/freezer not cold (Refrigerator & Freezer Repair)
by jzannini 9 years ago
Fridge and freezer too warm in my side by side refrigeratorld enough (Refrigerator & Freezer Repair)
by Majdo 9 years ago
Side by side refrigerator not cooling. (Refrigerator & Freezer Repair)
by Jms55 10 years ago
GE side by side refrigerator not holding temperature (Refrigerator & Freezer Repair)
by Jmatthew33 11 years ago
