The ice maker in our GE Arctica refrigerator/feezer stoppped working at some point over the past few days. The power indicator light is off even when the power switch is toggled in the on position. The ice make is plugged in and that connection seems to be secure. All other components in unit (door lights, compressor, etc.) have power and are functioning normally. Any suggestions you might have for troubleshooting this problem would be greatly appreciated.
Unplug the ice maker and check for 120 VAC between the brown and orange wires at the outlet. If the voltage is correct, replace the ice maker. If the voltage is incorrect, replace the main control board (on the back of the refrigerator). - The ice maker Part number: AP4345120
Originally Posted by: Gene  Unplug the ice maker and check for 120 VAC between the brown and orange wires at the outlet. If the voltage is correct, replace the ice maker. If the voltage is incorrect, replace the main control board (on the back of the refrigerator). - The ice maker Part number: AP4345120
Make sure the door switch is ENGAGED (manually) when testing.
