smedleybr
#1 Posted : Thursday, July 14, 2011 12:01:02 PM(UTC)
smedleybr
Oven does not heat, in order to cook at 300 degress you set the temp at 500. Was suggested by representive that we needed an oven probe. Ordered a WB21X5301, sensor ASM. The assembly appears to be for a burner as it has a place for a knob...Need your return policy.
Ruby Smedley
Jeff / APP Team
#2 Posted : Thursday, July 14, 2011 12:45:47 PM(UTC)
Jeff / APP Team
Hello smedleybr. You may have been sent the wrong part. Based on the part number you provided, it is the oven sensor. You can call us at 877-477-7278 and we will be glad to take care of you on this matter. Here is a link to our return policy as well. Here is a picture of the oven sensor part number you provided. Hope this helps.
Cancellations & Returns -- AppliancePartsPros.com
Part number: AP2023670
Oven does not heat to temperature set (Oven Repair (including Ranges and Cooktops))
by lauract 11/13/2015 12:53:01 PM(UTC)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
Oven does not heat past 270 (Oven Repair (including Ranges and Cooktops))
by frostyj50 11/18/2013 6:59:17 PM(UTC)
oven does not heat but stove works control panel works (Oven Repair (including Ranges and Cooktops))
by asfimag 11/10/2012 7:02:45 AM(UTC)
GE True Temp Electric Oven does not heat (Oven Repair (including Ranges and Cooktops))
by ksdavis1121 10/4/2012 11:43:04 AM(UTC)
Frigidaire oven does not heat (Oven Repair (including Ranges and Cooktops))
by camliv 9/30/2012 6:40:11 PM(UTC)
by camliv 9/30/2012 6:35:43 PM(UTC)
by escobedo55 3/11/2012 5:08:15 PM(UTC)
Oven does not heat / elements not working (Oven Repair (including Ranges and Cooktops))
by Steve Dyr59 3/8/2012 3:20:24 AM(UTC)
by davepechkis 12/6/2011 6:50:08 PM(UTC)
by fred08 9/2/2011 3:10:27 AM(UTC)
by tunnelwise 6/14/2011 12:41:11 PM(UTC)
oven does not heat to correct temp (Oven Repair (including Ranges and Cooktops))
by wawpooh 3/8/2011 11:54:18 AM(UTC)
oven does not heat up (Oven Repair (including Ranges and Cooktops))
by candyburch 2/4/2011 2:33:48 PM(UTC)
Oven Does Not Heat Up (Oven Repair (including Ranges and Cooktops))
by JIM1955 2/4/2011 6:23:20 AM(UTC)
