Oven does not heat, in order to cook at 300 degress you set the temp at 500. Was suggested by representive that we needed an oven probe. Ordered a WB21X5301, sensor ASM. The assembly appears to be for a burner as it has a place for a knob...Need your return policy.
Ruby Smedley
Hello smedleybr. You may have been sent the wrong part. Based on the part number you provided, it is the oven sensor. You can call us at 877-477-7278 and we will be glad to take care of you on this matter. Here is a link to our return policy as well. Here is a picture of the oven sensor part number you provided. Hope this helps. Cancellations & Returns -- AppliancePartsPros.com Part number: AP2023670
