Lizg23
#1 Posted : Wednesday, July 13, 2011 12:52:35 PM(UTC)
Lizg23
The water dispenser on my Whirlpool refrigerator is not working properly. At first, when it is engaged, water comes out, but soon (2-4 secs) the stream of water diminishes until it stops altogether. The ice maker is working fine. What can I do?
Jeff / APP Team
#2 Posted : Thursday, July 14, 2011 10:38:15 AM(UTC)
Jeff / APP Team
Hello Lizg23. Try removing the water line from the water valve and press the lever to dispense water. If it stops flowing at the valve, you will need to replace the water valve. Hope this helps.
Part number: AP3103466
Joe / APP Team
#3 Posted : Thursday, July 14, 2011 10:39:53 AM(UTC)
Joe / APP Team
Lizg,
Check the water tank/reservoir
Part number: AP3181346
and the tubing.
There could be a hairline crack in the reservoir, or a loose connection on the tubing, causing a pressure drop, otherwise it would be a bad fill valve.
Good Luck,
Water dispenser not working. (Refrigerator & Freezer Repair)
by DVDA247365 11/12/2013 11:44:19 AM(UTC)
water dispenser not working. (Refrigerator & Freezer Repair)
by food 3/5/2010 1:23:26 PM(UTC)
by Andrew DeLeon 4/12/2009 10:43:00 AM(UTC)
