I'm not sure of the model number. It is a super capacity, 6 cycle, 3 speed or something like that. Dryer works fine; however, there is kind of a odd smell to the clothes. Maybe kind of rubbery. What would cause this?
Remove the front panel and check for a burned lint inside. Also check for a clog in the vent and/or air ducts.
The model number is on the door frame.
