BORISM
#1 Posted : Sunday, March 8, 2009 1:56:32 PM(UTC)
BORISM
I Replaced Surface Bulbs Which I Purchased In Ace Hardware Bulbs Works However I Can Not Turned It Off
Does Anyone Know Why It Does Not Work?
TechnicianBrian
#2 Posted : Sunday, March 8, 2009 2:07:07 PM(UTC)
TechnicianBrian
If you can not turn off the surface lights by touching the control panel, it is usually because the bulb was changed with power applied and now the relay on the control board has shorted closed. Try cycling the power a few times to see if it frees the contacts, but if that doesn't work, then a new control board would be needed.
LED Bulb Kit for WMH73521CS-6 (Microwave Repair)
by captbrando 3/26/2024 12:03:20 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Oven light bulbs (Oven Repair (including Ranges and Cooktops))
by joea99 1/27/2023 3:17:03 PM(UTC)
Replacing the defrost heater, one bulb or two bulb heater? (Refrigerator & Freezer Repair)
by emilclintoc 7/12/2022 8:36:58 AM(UTC)
Change Microwave Bulb (Microwave Repair)
by Guest 6/20/2022 7:26:07 AM(UTC)
Replacement range light bulb won't turn off (Microwave Repair)
by kevink707 3/2/2022 8:03:45 AM(UTC)
Subzero 690 light bulb replacement (Refrigerator & Freezer Repair)
by dxg2 6/20/2021 4:41:56 PM(UTC)
Dryer Light Bulb (Dryer Repair)
by mike barnwell 8/7/2019 4:18:51 PM(UTC)
Maytag Washer light bulb. (MVWB955FC0) (Washer Repair)
by Draco911 7/4/2019 11:56:06 AM(UTC)
Micro wave bulb replacement (Microwave Repair)
by Wwolfe 7/18/2018 6:51:03 AM(UTC)
Jenn-Air combo wall oven microwave - light bulb (Microwave Repair)
by rschleicher 11/27/2017 4:48:05 PM(UTC)
Frigidaire dryer replace bulb (Dryer Repair)
by Sam Hobbs 12/11/2016 6:11:30 PM(UTC)
General Electric Thermostat Bulb Support (Oven Repair (including Ranges and Cooktops))
by ssauer40 11/25/2016 4:42:16 PM(UTC)
Replace refrigerator bulb with LED (Refrigerator & Freezer Repair)
by Kenwen 12/8/2015 2:10:03 PM(UTC)
Need a lightbulb for LG refrigirator (Refrigerator & Freezer Repair)
by mstrazhnik 7/24/2015 10:34:16 AM(UTC)
