The waher works great, however it will not spin. The lid switch meters good.
Does the motor run when spin is selected? If the motor runs, Check the DRIVE COUPLING!!!!:)
The motor runs great. Where would the drive coupler be located? :confused:
It is located between the Motor and the Transmission, If you lay the washer back so you can look under it, Its 2 white plastic pieces with a black rubber between them.:)
I checked the coupling and it looks good. What next?
I have checked the switch it meters good, checked the coupling it looks good and also the clutch looks good. Also the motor runs in the spin cycle I am lost please help with what it could be wrong.:confused:
As I stated the coupling (Drive Block) is good. If the motor and pump is working on spin in all three locations it's not the timer? Could it be in the transmisson? :rolleyes:
Coupling and drive block are absolutely different parts. Can you refer to the diagram numbers which part did you call "coupling"?
Does the washer drain? If it does then open and close the lid while it's draining. Post the results.
I the swith meters good also I have jumped it out of the loop.:cool:
