2 Pages12>
amburn02
#1 Posted : Saturday, March 7, 2009 11:44:59 AM(UTC)
amburn02
The waher works great, however it will not spin. The lid switch meters good.
Drags1998
#2 Posted : Saturday, March 7, 2009 12:03:13 PM(UTC)
Drags1998
Does the motor run when spin is selected? If the motor runs, Check the DRIVE COUPLING!!!!:)
amburn02
#3 Posted : Saturday, March 7, 2009 12:17:06 PM(UTC)
amburn02
The motor runs great. Where would the drive coupler be located? :confused:
Drags1998
#4 Posted : Saturday, March 7, 2009 12:37:22 PM(UTC)
Drags1998
It is located between the Motor and the Transmission, If you lay the washer back so you can look under it, Its 2 white plastic pieces with a black rubber between them.:)
amburn02
#5 Posted : Monday, March 9, 2009 12:04:18 PM(UTC)
amburn02
I checked the coupling and it looks good. What next?
amburn02
#6 Posted : Thursday, March 12, 2009 2:38:07 PM(UTC)
amburn02
I have checked the switch it meters good, checked the coupling it looks good and also the clutch looks good. Also the motor runs in the spin cycle I am lost please help with what it could be wrong.:confused:
#7 Posted : Friday, March 13, 2009 12:32:44 PM(UTC)
Check the drive block as described in one of our previous posts: http://forum.appliancepartspros...ir/373-not-spinning.html.
Here are the break down diagrams and Replacement parts for WHIRLPOOL LA5550XTW0 | AppliancePartsPros.com
amburn02
#8 Posted : Friday, March 13, 2009 2:47:50 PM(UTC)
amburn02
As I stated the coupling (Drive Block) is good. If the motor and pump is working on spin in all three locations it's not the timer? Could it be in the transmisson? :rolleyes:
#9 Posted : Friday, March 13, 2009 5:25:06 PM(UTC)
Coupling and drive block are absolutely different parts. Can you refer to the diagram numbers which part did you call "coupling"?
Does the washer drain? If it does then open and close the lid while it's draining. Post the results.
amburn02
#10 Posted : Friday, March 13, 2009 5:37:50 PM(UTC)
amburn02
I the swith meters good also I have jumped it out of the loop.:cool:
Guest (6)
2 Pages12>
