Discuss
not spinning
 in
Washer Repair
the washer will not spin on a full load and only will on a very small load if you help
Appliance Repair Forum > Appliance Repair Help > Washer Repair » not spinning
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 08-06-2007, 05:43 PM
peak_az@yahoo.com peak_az@yahoo.com is offline
Junior Member
peak_az@yahoo.com is on a distinguished road
Default not spinning
Model Number: 23832100   Brand: Kenmore   Age: 1 - 5 years
the washer will not spin on a full load and only will on a very small load if you help the tub start spinning
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-06-2007, 05:53 PM
Junior Member
Question not spinning
Quote:
  #3 (permalink)
Old 08-06-2007, 07:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check is the drive block. In order to do it you have to remove the cabinet and the agitator. Here is the complete instructions how to remove the cabinet and how to remove the agitator.
Remove the tub ring unsnapping the tub ring tabs from the tub one at a time.
Next step is to remove the spanner nut. You can do it using a hummer and
a screwdriver or you can buy a special spanner wrench
Carefully remove the basket by lifting straight up. Using a hummer, carefully tap up from the bottom of the drive block to remove.
Inspect notches on the drive block and tabs on the spin tube. If notches on the drive block are worn out, replace the drive block
If the problem is worn out tabs on the spin tube there is more serious job because the spin tube is a part of the basket drive/brakes assembly and to replace it you have to remove the gear case (aka transmission). Let me know if you are going to do it and I'll help you.
Good luck.
  #4 (permalink)
Old 01-19-2008, 01:00 PM
71trucklover 71trucklover is offline
Junior Member
71trucklover is on a distinguished road
Default same problem
I have the same problem did this fix it
  #5 (permalink)
Old 01-19-2008, 03:49 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
If you find the spin basket is tight on the spin tube, then you probably have a failed clutch, just check.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
