washer won't stop filling,keeps filling in wash cycle
The first thing I would check is the connection of the air pressure tube (#2 on the tub break down diagram) to the water level switch (#6 on the cabinet break down diagram). If there is nothing wrong then, most likely the water level switch is bad and has to be replaced. - The part number for the water level switch AP3750284 - Here are the break down diagrams for the Maytag washer Model LSE7806ACEGood luck. Gene.
