Terry Peters
#1 Posted : Monday, March 2, 2009 12:17:44 PM(UTC)
Terry Peters
Have GE Profile dishwasher and bottom of dishwasher retains water up to 1" deep. In looking at the exploded view, which shows the pump and the bottom spray arm, it appears the water coming into the washer is from below thru the pump moter assembly. I believe the water is exiting the rear (bottom) of the machine and no pressure operated drain is indicated on the schematic. When I cleaned out the standing water I cdid find some lint like material but it did not appear enough to block water from the rear drain. Please advise hopefully before I pull out the machine and make an a-- of myself (even more).
Many thanks,
Terry Peters
mizippipete@megagate.com
phone: 601-261-2508
Terry Peters
#2 Posted : Monday, March 2, 2009 12:19:52 PM(UTC)
Terry Peters
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Water Inlet Valve WR57X10033 / AP3189335 for General Electric DTL18ICSRRBS (Refrigerator & Freezer Repair)
by breckrider 1/18/2023 7:43:17 PM(UTC)
Temperature Sensor for General Electric GTS22KBPDRCC Frost buildup (Refrigerator & Freezer Repair)
by trm655 11/18/2021 12:53:19 PM(UTC)
General Electric Washer GTW330ASK1WW (Washer Repair)
by DMLane 5/18/2021 12:34:04 PM(UTC)
General Electric Washer WBB3300A0WW Noisy when spining (Washer Repair)
by profyler 7/27/2020 6:40:28 AM(UTC)
General Electric Thermostat Bulb Support (Oven Repair (including Ranges and Cooktops))
by ssauer40 11/25/2016 4:42:16 PM(UTC)
General Electric monogram series refrigerator (Refrigerator & Freezer Repair)
by Shemp 7/8/2015 12:56:56 PM(UTC)
General Electric Oven Issues (Oven Repair (including Ranges and Cooktops))
by celticfdguy 11/28/2012 7:56:59 AM(UTC)
General Electric WPRE6100G0WT Washer blown fuse (Washer Repair)
by donhans 9/14/2012 2:55:27 PM(UTC)
Funnel Fill Installation on a General Electric Dishwasher (Dishwasher Repair)
by Solan 8/9/2011 11:54:36 PM(UTC)
General Electric Refrigerator (Refrigerator & Freezer Repair)
by ricky1842 6/16/2011 1:19:53 PM(UTC)
General Electric Front load washer stuck in drain cycle (Washer Repair)
by Jasonkmol 6/7/2011 8:34:56 AM(UTC)
General Electric - Clothes Washer | GEĀ® 3.2 Cu. Ft. Super Plus (Washer Repair)
by LUCIENC 4/21/2011 2:27:26 PM(UTC)
Clunk Noise - General Electric TBX22ZAZBRWW Refrigerator (Refrigerator & Freezer Repair)
by RT37 11/30/2010 2:23:45 AM(UTC)
General Electric spin cycle roaring loudly (Washer Repair)
by Jamie Mitchell 11/21/2010 3:48:15 PM(UTC)
general electric range (Oven Repair (including Ranges and Cooktops))
by feb 3/26/2010 12:53:58 PM(UTC)
