pgronvall
#1 Posted : Tuesday, November 6, 2007 4:59:06 PM(UTC)
pgronvall
Worked fine for years. This unit fills, runs then when finished there is soap suds in the bottom with water just to the inside bottom of the fine screen. I only have used dishwashing machine soap (cascade) and use jet dry in the correct dispenser (verified with my sometimes confused wife). It has started to make what I call a vibration "cow mooing" noise while running, it makes this noise only sporadically. I have cleaned the fine screen and large trap screen. I have removed the small drain cover and cleaned out some popcorn seeds, and the impeler turns ok, it turns and snaps forward as if a rubber band is wound inside somewhere, buts spins ok. I stuck my finger into the drain hole, there apears to be a back flow check flap. I held the check flap open, and disconnected the drain line from the disposal and blew thru the drain hose and got good flow back into the unit thu the check valve so I don't think the hose is clogged. I do notice water running at drain time thru the disposal when hooked up. I'm at a loss? Never had suds before, it covers the bottom after running up to the bottom of the bottom rack. I have run the unit empty on several cycles, in different modes, and done a rinse and hold, and cancel drain only..........still has suds.......................
Kenmore series 500 brake release problem (Washer Repair)
by walbar1516 6/29/2024 10:20:56 AM(UTC)
Whirlpool WRF757SDEM01 led light problem (Refrigerator & Freezer Repair)
by Guest 3/16/2024 1:02:12 PM(UTC)
Kitchen Aid Electric Rang Power Problem (Oven Repair (including Ranges and Cooktops))
by Guest 3/10/2024 7:24:24 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
problem with no ice in bottom ice maker (Refrigerator & Freezer Repair)
by Daver032 11/29/2023 6:13:20 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
kenmore refrige problems (Refrigerator & Freezer Repair)
by jkoppen73 11/13/2023 6:58:09 AM(UTC)
Refrigerator Valve or Computer Problem? (Refrigerator & Freezer Repair)
by fallman237 10/8/2023 2:22:06 PM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Whirlpool front load washer WFW9620HBK0 problems (Washer Repair)
by ctbirkett 8/28/2023 4:28:27 AM(UTC)
Speed Queen washer problem (Washer Repair)
by Guest 7/21/2023 1:04:45 PM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Roper Top Load Washer RAS7133PQ0 Problem (Washer Repair)
by nkaufman1 4/7/2023 9:02:20 AM(UTC)
