Hello,this is my 1st time using your site & I need your help.my dryer won't heat & i've got good voltage & dryer turns.book say's possible 1 of 2 fuses bad.problem is i don't have a instruction booklet to locate the fuses,could you please help.
If the dryer runs, and does not heat, it will not be the limit switch. You, have to remove the top, and in the back up top is the high limit switch. Make sure the dryer is unplugged, and ohm it out. If it is good, you will have to check the element. But, alot of people say the dryer has power, but are not using a meter to check it. You need to check power, where the plug comes into the dryer. A dryer will run with 1/2 the power, but it won't heat. Tom ApplianceEducator.com
