2 Pages12>
gm589
#1 Posted: : Monday, November 5, 2007 3:12:48 PM(UTC)
gm589
goes through the cycles alright but won't spin out
#2 Posted : Monday, November 5, 2007 5:31:50 PM(UTC)
Hi gm589
In order to provide the most accurate advise I need the complete model number of your washer. Instead of the model number you posted a serial number.
gm589
#3 Posted : Tuesday, November 6, 2007 12:08:10 PM(UTC)
gm589
I found under the lid a number marked MOD RAS7133R00 then a number marked SER CS3307997
#4 Posted : Friday, November 9, 2007 12:14:53 PM(UTC)
Hi gm589
If your washer does agitate but does not drain and spin then most likely the problem is a bad lid switch.
If does not agitate and spin but does drain then the problem is a bad motor drive coupling.
If does agitate and drain but does not spin at all then it could be a bad drive block, a bad clutch or a bad transmission (the transmission should be under the limited manufacturer warranty).
To tell you more specific what is wrong with your washer I need more information.
- Here are the break down diagrams for the Roper washer Model RAS7133KQ0
gm589
#5 Posted : Friday, November 9, 2007 1:44:26 PM(UTC)
gm589
The machine does aggitate all the time and does drain all of the time. To get it to spin I have to turn the drum back and fourth like it was aggitating and then when I put the lid down it will spin.
#6 Posted : Friday, November 9, 2007 6:27:42 PM(UTC)
The first thing I would check in such situation is the drive block.
Remove the agitator and the spanner nut. Visually inspect the drive block. If it has to be replaced you will have to remove the cabinet and the inner tub.
In order to remove the spanner nut you will need a special spanner wrench.
- The part number for the spanner wrench AP3538707
- The part number for the drive block AP2905773
The drive block
UserPostedImage
okbobcats
#7 Posted : Sunday, November 11, 2007 12:42:25 PM(UTC)
okbobcats
after your water drains out. does your motor stop. and then starts again. if so your timer is good. if not you tranny could be bad.
Ryan Dingmann
#8 Posted : Wednesday, December 31, 2008 7:31:51 AM(UTC)
Ryan Dingmann
Gene, thanks for the info, I also have a Roper washer, and when I look under the lid on mine, I see toward the top - SM 8280871. I am also having these same issues, washer agitates & drains well, but does not spin. Do you have the break down diagrams for my model number ?? Thanks!
#9 Posted : Saturday, January 3, 2009 9:10:11 PM(UTC)
Hi Ryan,
The number you posted is the serial number. The model number should be on the same name plate.
Try to open and close the lid while it's draining. If it will start to spin then the problem is a bad timer.
Ryan Dingmann
#10 Posted : Wednesday, January 7, 2009 4:24:54 PM(UTC)
Ryan Dingmann
Hey there Gene, thanks for the response......
I did try and opened the lid while the washer was draining, and then closed the lid. But the washer just continued with it's cycle, and tried to spin, making a grinding noise as if it was trying to spin. It is not an extremely loud grinding, but I can tell it is definitely trying to spin it seems. Would I check the drive block next ?? Please advise......
Also, I did find the part number under the lid as well -
Roper - RAX7245KQ0
Type - 107
Thanks!
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 3/15/2024 9:35:49 AM(UTC)
Samsung washer won't spin (Washer Repair)
by Guest 1/8/2022 10:56:39 AM(UTC)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4/7/2021 8:42:00 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 2/21/2019 4:21:02 AM(UTC)
Washer won't spin out. (Washer Repair)
by DJChad818 10/26/2017 9:47:20 AM(UTC)
Washer won't spin (Washer Repair)
by Fingers123 10/22/2017 1:43:41 PM(UTC)
Washer Won't Spin (Washer Repair)
by je00409 9/5/2017 11:00:04 AM(UTC)
Washer won't spin or agitate (Washer Repair)
by dhughes 4/1/2017 10:17:04 AM(UTC)
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 3/21/2017 7:08:08 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 1/3/2017 2:58:09 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
by lmhansgen 8/31/2016 10:19:23 AM(UTC)
2 Pages12>
