2 Pages12>
gm589
#1 Posted : 17 years ago
gm589
goes through the cycles alright but won't spin out
#2 Posted : 17 years ago
Hi gm589
In order to provide the most accurate advise I need the complete model number of your washer. Instead of the model number you posted a serial number.
gm589
#3 Posted : 17 years ago
gm589
I found under the lid a number marked MOD RAS7133R00 then a number marked SER CS3307997
#4 Posted : 17 years ago
Hi gm589
If your washer does agitate but does not drain and spin then most likely the problem is a bad lid switch.
If does not agitate and spin but does drain then the problem is a bad motor drive coupling.
If does agitate and drain but does not spin at all then it could be a bad drive block, a bad clutch or a bad transmission (the transmission should be under the limited manufacturer warranty).
To tell you more specific what is wrong with your washer I need more information.
- Here are the break down diagrams for the Roper washer Model RAS7133KQ0
gm589
#5 Posted : 17 years ago
gm589
The machine does aggitate all the time and does drain all of the time. To get it to spin I have to turn the drum back and fourth like it was aggitating and then when I put the lid down it will spin.
#6 Posted : 17 years ago
The first thing I would check in such situation is the drive block.
Remove the agitator and the spanner nut. Visually inspect the drive block. If it has to be replaced you will have to remove the cabinet and the inner tub.
In order to remove the spanner nut you will need a special spanner wrench.
- The part number for the spanner wrench AP3538707
- The part number for the drive block AP2905773
The drive block
UserPostedImage
okbobcats
#7 Posted : 17 years ago
okbobcats
after your water drains out. does your motor stop. and then starts again. if so your timer is good. if not you tranny could be bad.
Ryan Dingmann
#8 Posted : 16 years ago
Ryan Dingmann
Gene, thanks for the info, I also have a Roper washer, and when I look under the lid on mine, I see toward the top - SM 8280871. I am also having these same issues, washer agitates & drains well, but does not spin. Do you have the break down diagrams for my model number ?? Thanks!
#9 Posted : 16 years ago
Hi Ryan,
The number you posted is the serial number. The model number should be on the same name plate.
Try to open and close the lid while it's draining. If it will start to spin then the problem is a bad timer.
Ryan Dingmann
#10 Posted : 16 years ago
Ryan Dingmann
Hey there Gene, thanks for the response......
I did try and opened the lid while the washer was draining, and then closed the lid. But the washer just continued with it's cycle, and tried to spin, making a grinding noise as if it was trying to spin. It is not an extremely loud grinding, but I can tell it is definitely trying to spin it seems. Would I check the drive block next ?? Please advise......
Also, I did find the part number under the lid as well -
Roper - RAX7245KQ0
Type - 107
Thanks!
3 year old top loading washer won't spin clothes dry (Washer Repair)
by craig100 12 months ago
Samsung washer won't spin (Washer Repair)
by Guest 3 years ago
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 3 years ago
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4 years ago
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 5 years ago
Whirlpool LSN2000LW Washer Won't Spin, Buzzes (Washer Repair)
by Robb235 6 years ago
Washer won't spin out. (Washer Repair)
by DJChad818 7 years ago
Washer won't spin (Washer Repair)
by Fingers123 7 years ago
Washer Won't Spin (Washer Repair)
by je00409 7 years ago
Washer won't spin or agitate (Washer Repair)
by dhughes 8 years ago
Whirlpool belt drive washer won't spin. (Washer Repair)
by weswoodallz21 8 years ago
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 8 years ago
Whirlpool washer won't spin or drain (Washer Repair)
by ronaldjp1 8 years ago
maytag washer won't spin fast (Washer Repair)
by benp1 8 years ago
by lmhansgen 9 years ago
2 Pages12>
