ezak
#1 Posted : Tuesday, February 3, 2009 7:45:23 AM(UTC)
ezak
Ran the self cleaning cycle which worked fine. When I tried to use the oven several days later---NO HEAT.
Reset the breaker but did not help. The stovetop works ok. Control panel works.
I can set the oven temp for bake or broil. When I press start I hear the relay click but elements don't get hot.
I replaced the bake element less last year.
Any ideas?
#2 Posted : Wednesday, February 4, 2009 1:41:05 PM(UTC)
Pull the range out of the wall, remove the back panel and check the safety thermostat (#9 on the break down diagram) for continuity. Replace if it's open.
- The part number for the thermostat is AP2928571
Here are the break down diagrams for the Kitchen Aid range Model KESC300BAL5
Gas Oven not heating up (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 7:09:48 PM(UTC)
Thermadore PRG304GH oven not heating (Oven Repair (including Ranges and Cooktops))
by Guest 12/15/2022 6:58:50 AM(UTC)
upper oven not heating up to desired temp. it's off by about 50 degrees (Oven Repair (including Ranges and Cooktops))
by Guest 10/14/2022 12:50:23 PM(UTC)
Bottom oven not heating (Oven Repair (including Ranges and Cooktops))
by Castelle 1/21/2022 6:17:26 PM(UTC)
Monogram electric oven not heating (Oven Repair (including Ranges and Cooktops))
by Norploc 2/26/2021 12:56:03 PM(UTC)
Frigidaire GLEF378CBD - oven not heating (Oven Repair (including Ranges and Cooktops))
by canooten 3/20/2020 11:24:19 AM(UTC)
by deanowhitney 7/11/2018 11:22:38 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
Oven not heating when using convection (Oven Repair (including Ranges and Cooktops))
by ebonyclose 3/11/2018 7:37:25 PM(UTC)
Frigidaire Double Oven - Lower Oven not heating - Clicking (Oven Repair (including Ranges and Cooktops))
by RentAHubby 10/3/2017 8:42:44 PM(UTC)
Whirlpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by proto8432 7/15/2017 10:07:03 AM(UTC)
Oven not heating up and gas smell in house (Oven Repair (including Ranges and Cooktops))
by DJKNY71 1/18/2017 7:06:47 AM(UTC)
Upper oven not heating, lower over works properly (Oven Repair (including Ranges and Cooktops))
by Greg2cycle 11/5/2016 9:50:34 AM(UTC)
Oven not heating properly (Oven Repair (including Ranges and Cooktops))
by Rentalmom5 9/14/2016 6:24:38 AM(UTC)
Whirpool Oven not heating (Oven Repair (including Ranges and Cooktops))
by cdfrerichs01 8/7/2016 10:55:06 AM(UTC)
