drembo
#1 Posted : 17 years ago
drembo
Our washer stopped in the middle of a cycle. Tub is full of water. When setting the timer any where in the cycle, the washer makes some grinding type noises, and then the overload protection turns the thing off. The tub seems to spin freely by hand. Pump, agitator, and spin will not work.
fixxit
#2 Posted : 17 years ago
fixxit
quite likely you have a pump that is frozen. relizing your tub is half full you might want to use a pail or wet dry shop vac to empty as much water out of it as you can. then tilt it back and see if the pump is free. try not to run it much or you will burn the motor out. part # for the pump if it is the pump is AP3447809. good luck and post your results here
drembo
#3 Posted : 17 years ago
drembo
You are correct, sir!! It was/is the pump
slofeet
#4 Posted : 17 years ago
slofeet
washer fills up with water won't drain out and makes humming noise
slofeet
#5 Posted : 17 years ago
slofeet
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
slofeet
#6 Posted : 17 years ago
slofeet
how do you know if the washer is frozen? and how can i fix it the washer will turn on and sometimes spin and makes a humming noise but will not drain water at all.
slofeet
#7 Posted : 17 years ago
slofeet
you are crazy
#8 Posted : 17 years ago
Uh, drain the washer and check!!
