drembo
#1 Posted : Saturday, November 3, 2007 11:27:04 AM(UTC)
drembo
Our washer stopped in the middle of a cycle. Tub is full of water. When setting the timer any where in the cycle, the washer makes some grinding type noises, and then the overload protection turns the thing off. The tub seems to spin freely by hand. Pump, agitator, and spin will not work.
fixxit
#2 Posted : Saturday, November 3, 2007 12:26:35 PM(UTC)
fixxit
quite likely you have a pump that is frozen. relizing your tub is half full you might want to use a pail or wet dry shop vac to empty as much water out of it as you can. then tilt it back and see if the pump is free. try not to run it much or you will burn the motor out. part # for the pump if it is the pump is AP3447809. good luck and post your results here
drembo
#3 Posted : Saturday, November 3, 2007 2:49:41 PM(UTC)
drembo
You are correct, sir!! It was/is the pump
slofeet
#4 Posted : Monday, December 24, 2007 4:47:01 PM(UTC)
slofeet
washer fills up with water won't drain out and makes humming noise
slofeet
#5 Posted : Monday, December 24, 2007 4:47:41 PM(UTC)
slofeet
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
slofeet
#6 Posted : Monday, December 24, 2007 4:55:27 PM(UTC)
slofeet
how do you know if the washer is frozen? and how can i fix it the washer will turn on and sometimes spin and makes a humming noise but will not drain water at all.
slofeet
#7 Posted : Monday, December 24, 2007 5:08:27 PM(UTC)
slofeet
you are crazy
#8 Posted : Tuesday, December 25, 2007 1:37:36 AM(UTC)
Uh, drain the washer and check!!
