I am attempting to determine what all needs replacement in the defrost system. The thermostat has 6.1k ohms at room temperature and I haven't read the heater yet. What reading should I get there and what other tests should I perform if the redings are in the good range?
THIS FORUM IS DEAD!!!!!!! |
