wzard841
#1 Posted : Saturday, May 14, 2011 4:13:39 PM(UTC)
wzard841
I am attempting to determine what all needs replacement in the defrost system. The thermostat has 6.1k ohms at room temperature and I haven't read the heater yet. What reading should I get there and what other tests should I perform if the redings are in the good range?
#2 Posted : Sunday, May 15, 2011 5:07:18 AM(UTC)
Replacement parts for FRIGIDAIRE PHSC39EESS3 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241639000.pdf
The defrost element should be around 30 ohms.
The defrost thermostat should be 0 ohms when frozen. Unplug the unit and one side of the defrost thermostat then hold it's face not an ice cube to see if it will close.
The resistance you see is probably normal when it is open.
If the defrost thermostat is bulged/deformed replace it even if it does measure OK.
Try to force a defrost, see the tech sheet.
If the heater comes on then probably the control board needs replacing.
Be careful that you do not burn your fingers.
MayTag defrost issues ????? (Refrigerator & Freezer Repair)
by HHM1435 10/16/2017 1:03:48 PM(UTC)
GE Defrost Issues (Refrigerator & Freezer Repair)
by WVU 9/23/2014 7:40:11 AM(UTC)
defrost issues (Refrigerator & Freezer Repair)
by jbain7005 10/16/2013 3:44:10 AM(UTC)
Freezer Defrost Issues (Refrigerator & Freezer Repair)
by smuth10 5/9/2013 5:10:31 AM(UTC)
Defrost issues (Refrigerator & Freezer Repair)
by zeke7237 9/23/2011 3:29:06 AM(UTC)
Freezer with defrost issues - dripping water inside. (Refrigerator & Freezer Repair)
by mbockus 8/22/2011 7:43:05 PM(UTC)
by Dennis3816 5/20/2011 10:33:38 AM(UTC)
by stem300 1/18/2011 1:39:02 PM(UTC)
troubleshooting defrost issues (Refrigerator & Freezer Repair)
by iccheap 7/2/2010 11:43:11 AM(UTC)
by wzard841 6/14/2010 6:03:18 AM(UTC)
GE Refrigerator Defrost Issues (Refrigerator & Freezer Repair)
by bhavinjo 5/3/2010 6:01:34 PM(UTC)
Defrost issues with electronoc control (Refrigerator & Freezer Repair)
by dw85075 3/31/2010 6:06:54 PM(UTC)
more defrost issues (Refrigerator & Freezer Repair)
by davidp 1/14/2010 6:54:47 PM(UTC)
GE side by side defrost issues, I looked (Refrigerator & Freezer Repair)
by Hankster 2/3/2008 5:36:29 AM(UTC)
