wzard841
#1 Posted : 14 years ago
wzard841
I am attempting to determine what all needs replacement in the defrost system. The thermostat has 6.1k ohms at room temperature and I haven't read the heater yet. What reading should I get there and what other tests should I perform if the redings are in the good range?
#2 Posted : 14 years ago
Replacement parts for FRIGIDAIRE PHSC39EESS3 Frigidaire/refrigerator | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/241639000.pdf
The defrost element should be around 30 ohms.
The defrost thermostat should be 0 ohms when frozen. Unplug the unit and one side of the defrost thermostat then hold it's face not an ice cube to see if it will close.
The resistance you see is probably normal when it is open.
If the defrost thermostat is bulged/deformed replace it even if it does measure OK.
Try to force a defrost, see the tech sheet.
If the heater comes on then probably the control board needs replacing.
Be careful that you do not burn your fingers.
MayTag defrost issues ????? (Refrigerator & Freezer Repair)
by HHM1435 7 years ago
GE Defrost Issues (Refrigerator & Freezer Repair)
by WVU 11 years ago
defrost issues (Refrigerator & Freezer Repair)
by jbain7005 11 years ago
Freezer Defrost Issues (Refrigerator & Freezer Repair)
by smuth10 12 years ago
Defrost issues (Refrigerator & Freezer Repair)
by zeke7237 14 years ago
Freezer with defrost issues - dripping water inside. (Refrigerator & Freezer Repair)
by mbockus 14 years ago
by Dennis3816 14 years ago
by stem300 14 years ago
troubleshooting defrost issues (Refrigerator & Freezer Repair)
by iccheap 15 years ago
by wzard841 15 years ago
GE Refrigerator Defrost Issues (Refrigerator & Freezer Repair)
by bhavinjo 15 years ago
Defrost issues with electronoc control (Refrigerator & Freezer Repair)
by dw85075 15 years ago
more defrost issues (Refrigerator & Freezer Repair)
by davidp 15 years ago
GE side by side defrost issues, I looked (Refrigerator & Freezer Repair)
Belarus Hankster 17 years ago
