mpalmatier
#1 Posted : Saturday, January 24, 2009 8:16:59 AM(UTC)
mpalmatier
My water dispenser was leaking water from behind the panel, the hose had popped out (2nd time this has happened. After opening the panel and replacing the hose, I hooked everything back up and the ice dispenser would not stop dispensing, it was getting a constant signal every time I plugged the cable back in. I took both boards out trying to find an obvious problem, which I didn't. Now I get no power to the dispenser at all when I hook everything back up. I'm not sure what parts to replace, the front circuit board, rear board or the harness cable. I'd rather not buy all 3 parts to find out I only needed one. Any thoughts?
#2 Posted : Monday, January 26, 2009 2:43:25 PM(UTC)
Most likely the problem is a bad power board (#38 on the break down diagram).
Here are the break down diagrams for the Frigidaire refrigerator Model FSC23F7DSB9
frigidaire ice maker 241642503 not working (Refrigerator & Freezer Repair)
by jesus freak 8/1/2023 3:07:31 PM(UTC)
Frigidaire ice maker and water dispenser not working (Refrigerator & Freezer Repair)
by goozpah 1/20/2023 6:39:18 AM(UTC)
Frigidaire Ice Maker Arm won't move (Refrigerator & Freezer Repair)
by Guest 7/10/2022 6:18:09 PM(UTC)
Frigidaire ice maker not working (Refrigerator & Freezer Repair)
by lilacreality 1/4/2016 1:38:29 PM(UTC)
Frigidaire Ice maker only making huge chunks (Refrigerator & Freezer Repair)
by WAKS 10/14/2015 6:46:20 PM(UTC)
frigidaire ice maker not working (Refrigerator & Freezer Repair)
by joeyjags 3/23/2015 10:39:43 AM(UTC)
Frigidaire Ice Maker Won't Turn Off (Refrigerator & Freezer Repair)
by Fathergoose007 9/7/2014 2:15:19 PM(UTC)
Frigidaire Ice Maker--making noise/not making ice (Refrigerator & Freezer Repair)
by lak 6/23/2013 3:03:35 PM(UTC)
Frigidaire Ice maker making ice very slow. (Refrigerator & Freezer Repair)
by Mrpaul88 7/27/2012 7:59:50 AM(UTC)
Frigidaire Ice Maker (Refrigerator & Freezer Repair)
by RSP3 12/23/2011 8:46:23 AM(UTC)
No water to Frigidaire ice maker. (Refrigerator & Freezer Repair)
by Ice Master 11/22/2011 8:59:04 AM(UTC)
Frigidaire Ice maker Valve not open (Refrigerator & Freezer Repair)
by jkor 5/20/2011 1:55:01 PM(UTC)
Frigidaire ice maker control panel has no power (Refrigerator & Freezer Repair)
by F1USGP 2/20/2011 2:15:22 PM(UTC)
Frigidaire ice maker switch shut off arm won't go down to on (Refrigerator & Freezer Repair)
by lcapelis 4/9/2010 1:31:50 AM(UTC)
by luigys22 2/22/2010 6:25:14 AM(UTC)
