bea
#1 Posted : 16 years ago
bea
I have 2 questions. On my maytag model mzd2766gew. I have a problem with the freezer opening when I close the frig. What could that be about. And the outside dispenser needs replacing. the key pad is breaking and rusting. Can i replace just those parts.
#2 Posted : 16 years ago
Here is your parts breakdown
Model MZD2766GEW
See section 6 "Freezer outer door"
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16010154.pdf
You may want to check the doors bottom hinge. There is a plastic cam assembly here. Perhaps it is worn or damaged.
Also check the level of the fridge.
Make sure side to side is level
Front to back. Does not hurt to have it tilt slightly to the back.
Also sometimes and indicator that the freezer drain is partially plugged.
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 12 months ago
Removal of French Freezer door on Frigidaire Gallery (Refrigerator & Freezer Repair)
by Guest 2 years ago
Refrigerator and Freezer Doors (Refrigerator & Freezer Repair)
by AeroncaChief 2 years ago
GE Side-by-Side freezer door dispenser leaking (ESS25LRBSS) (Refrigerator & Freezer Repair)
by dhunsing 3 years ago
KBUDT4270A/02 SXS freezer door gasket (Refrigerator & Freezer Repair)
by metropical 3 years ago
Refrigerator and freezer door lights reversed - KitchenAid KSCS25FJSS (Refrigerator & Freezer Repair)
by blacter 3 years ago
Freezer door/drawer not closing (Refrigerator & Freezer Repair)
by mwarney 4 years ago
How to disassemble the freezer door (Refrigerator & Freezer Repair)
by cparke 4 years ago
Broken Freezer Door Handle (Refrigerator & Freezer Repair)
by Guest 4 years ago
Frigidaire Freezer Door Pops When Opening - FFHB2750TS / Effortless Glide / Under French Doors (Refrigerator & Freezer Repair)
by daved31415 4 years ago
Replace water line in freezer door of GE GSF25IGXNBB (Refrigerator & Freezer Repair)
by splinke 4 years ago
Freezer door opens fridge door every time (Refrigerator & Freezer Repair)
by coyote2 5 years ago
Ice dispenses when freezer door closes (Refrigerator & Freezer Repair)
by wrb 6 years ago
Fridge and Freezer door sag (Refrigerator & Freezer Repair)
by WLHuard 7 years ago
Bottom of freezer door sticks out (Refrigerator & Freezer Repair)
by smithd441@gmail.com 8 years ago
