I have a Sears Kenmore "French Door" refrigerator with bottom pull out freezer. Model number 25370413417. Model beginning 253 indicates it was made by Gibson (Frigidaire). The freezer drawer is not fully closing on the right hand side. So if you were to stand closely in front of the fridge and look down at the freezer drawer, it protrudes about 1/4 inch on the right while the left side is flush with the refrigerator doors. I thought that there must be an adjustment for this but can't seem to locate anything obvious on the drawer glides or the door. The seal on the right is just lightly touching the fridge but not compressing so we are getting frost inside the unit. I would much appreciate if anyone can explain how to adjust this or could point me toward a solution. Thanks in advance.
