wrb
#1 Posted: : Saturday, May 4, 2019 8:08:13 AM(UTC)
wrb
United States
Hello, I have a side by side Frigidaire FRS26H5ASB4 and when the freezer door closes it triggers the ice dispenser to activate for just a second. This causes a small amount of ice to get stuck dispense. I checked and it is the freeze light switch that is causing the actual activation. It happens every time the light switch is pressed in. Any help on what might to causing this, or how to isolate the problem would greatly be appreciated.
KingGuy77
#2 Posted : Wednesday, September 2, 2020 1:55:53 PM(UTC)
KingGuy77
United States
Did you find a solution to this? I have the exact same issue. Drives me crazy.
