pls418
#1 Posted : Tuesday, May 3, 2011 6:19:41 PM(UTC)
pls418
I need to replace my lower oven element. I have determined which element I need to order but I want to make sure it is actually the element. Can I take it out and use an ohm meter? Also when I take out the two screws holding the element and pull it forward a couple inches it seems to be pulling out two wires with it. How do they unplug? How far do I dare pull it out? Thank you.
Steve
#2 Posted : Wednesday, May 4, 2011 5:31:06 AM(UTC)
Replacement parts for mer6555 models | AppliancePartsPros.com
See the attachment for the tech sheet
Be sure to remove power from the unit when working on it. Many units still have power to one side of the element even with the element shut off. I am not sure if this is the case with this unit but better safe than sorry.
[COLOR="DarkRed"]Can I take it out and use an ohm meter?[/COLOR]
Yes, see the tech sheet for what it should measure as you did not say which element in the lower oven needs replacing.
[COLOR="DarkRed"]How do they unplug?[/COLOR]
The connectors should just push off. Just be sure not to pull on the wires themselves.
Until there is some resistance, just don't yank on them.
Also it is a good idea to clip something onto the wires (clothespin etc> ) so that they do not disappear into the back of the unit before you get the new element attached.
File Attachment(s):
MER6555.pdf (721kb) downloaded 5 time(s).
pls418
#3 Posted : Wednesday, May 4, 2011 8:23:23 AM(UTC)
pls418
denman,
Thanks for the reply. In the tech sheet the picture of the bake element is different then the one I need AP4094020. It is the very bottom element in the double oven. Maybe the picture doesn't matter, the specs were 21.3 ohms. My experience with a ohm meter has really only been to check for open circuits. So in this case after I adjust my meter on the X1 scale if it reads infinity I know its bad. Are there times when the element is bad and still reads resistance? If 21.3 is the correct reading for that element what kind of variation would I be looking for and would it be higher or lower? Thanks again.
Steve
#4 Posted : Wednesday, May 4, 2011 10:08:41 AM(UTC)
The element could be either higher or lower.
Usually if they are abd they will be an open.
Also I do not know what meter you are using and what the X1 scale's spec is.
As an example if the scale is 1 to 20 ohms then anything over 20 ohms would read as an open.
GE oven bake element (Oven Repair (including Ranges and Cooktops))
by 72yrsoldwoman 10/27/2023 6:22:03 PM(UTC)
Whirlpool oven bake element doesn't come on (Oven Repair (including Ranges and Cooktops))
by Gotzman 1/16/2016 8:41:52 AM(UTC)
ge oven bake element will not turn off (Oven Repair (including Ranges and Cooktops))
by rgaden 8/20/2014 9:51:39 AM(UTC)
Kenmore Elite Oven bake element not heating (Oven Repair (including Ranges and Cooktops))
by ADN140 12/16/2013 12:24:26 PM(UTC)
Oven bake element works sometimes (Oven Repair (including Ranges and Cooktops))
by tallshouse 3/4/2013 7:05:10 AM(UTC)
Oven Bake Element (Oven Repair (including Ranges and Cooktops))
by JMAL 4/25/2012 8:47:14 AM(UTC)
oven bake element required (Oven Repair (including Ranges and Cooktops))
by Olga-C 4/20/2012 10:04:16 AM(UTC)
Attempting to install a oven bake element (Oven Repair (including Ranges and Cooktops))
by livelifeest1973 3/9/2012 12:36:51 PM(UTC)
by carguy50 2/23/2012 1:55:12 PM(UTC)
by Dolores814 1/13/2012 10:36:05 AM(UTC)
GE oven bake element not working, broil works. (Oven Repair (including Ranges and Cooktops))
by HelpMeAnyone 12/25/2011 3:39:09 PM(UTC)
Oven bake element lead (Oven Repair (including Ranges and Cooktops))
by Ctwild 12/5/2011 4:33:39 AM(UTC)
Oven Bake element not working (Oven Repair (including Ranges and Cooktops))
by NickJade 11/14/2011 8:17:42 AM(UTC)
Oven bake element does not heat (Oven Repair (including Ranges and Cooktops))
by crna1 7/5/2011 11:18:31 AM(UTC)
Magic Chef oven bake element (Oven Repair (including Ranges and Cooktops))
by Rafat 6/29/2011 11:42:53 AM(UTC)
