livelifeest1973
#1 Posted : Friday, March 9, 2012 12:36:51 PM(UTC)
livelifeest1973
I am attempting to install a oven bake element (Part Number AP436505). There are two wires that are connected to the current element, one on each side. Can these be removed by hand? I did not want to break anything, because I tried to to pull these out with little force. please assist. Thank you.:confused:
#2 Posted : Sunday, March 11, 2012 3:49:26 AM(UTC)
Yes they can be removed.
If you are sure the element is toast, you can grab the element's connector or element on the element side with a pair of needle nose or regular pliers.
Then with a flat screwdriver wedged between the pliers and the female connector push the connector back off the element's male connector.
