misterfixall
#1 Posted : Wednesday, January 21, 2009 2:25:26 PM(UTC)
misterfixall
hi ,amana oven door latching +unlatching in self clean +showin f9 . i feel that beacause the door does lock +unlock when it shouldnt, the problem is with circuit relay board, part#ap4280300, do you agree? oh ya fellow americans, congrats on your new President ,
#2 Posted : Thursday, January 22, 2009 12:39:51 PM(UTC)
I would check first the door latch switches and the wire harness. The relay board is very last on the list of suspects. In case if you did not find the wiring diagram, here is the tech sheets.
misterfixall
#3 Posted : Thursday, January 22, 2009 1:38:47 PM(UTC)
misterfixall
Gene if door locks securely when set to clean . then after a couple of minutes it unlocks , then if you cancel +repeat clean, it locks again for a short time, wouldnt that mean that door latch switches are working?
#4 Posted : Thursday, January 22, 2009 2:52:21 PM(UTC)
It could be improper feedback to the control board.
misterfixall
#5 Posted : Thursday, January 22, 2009 3:33:39 PM(UTC)
misterfixall
please explain what improper feedback is +and if so what would i be checking
#6 Posted : Thursday, January 22, 2009 3:40:32 PM(UTC)
The control board reads the open or close position of these switches to determine if the door is locked, then it stops the latch motor and starts the self clean. You have to check the switches for continuity according to the wiring diagram and position of the latch cam.
misterfixall
#7 Posted : Thursday, January 22, 2009 3:56:50 PM(UTC)
misterfixall
i will be pulling it out tomorrow. i printed out out the tech sheets and will be checking out the switches in clean mode, will keep you informed, thanks
Amana oven (insert) turns off (Oven Repair (including Ranges and Cooktops))
by Melodyportillo 12/29/2019 10:12:09 AM(UTC)
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
How to access amana oven door latch (Oven Repair (including Ranges and Cooktops))
by Handyguy1 9/30/2015 7:39:03 PM(UTC)
Amana oven not heating (Oven Repair (including Ranges and Cooktops))
by myrnarud 9/24/2014 7:15:11 PM(UTC)
Amana Oven/Range Fuse? (Oven Repair (including Ranges and Cooktops))
by sashko 3/20/2014 1:45:41 PM(UTC)
how do I replace relay board on amana oven (Oven Repair (including Ranges and Cooktops))
by ghappe 11/4/2013 11:30:31 AM(UTC)
Amana Oven Fails after Power Failure (Oven Repair (including Ranges and Cooktops))
by newatappliancerepair 2/4/2013 9:05:57 PM(UTC)
Amana Oven Problem (Oven Repair (including Ranges and Cooktops))
by JOHN S. 1/10/2013 5:50:09 PM(UTC)
Amana oven temp keeps climbing then display goes out (Oven Repair (including Ranges and Cooktops))
by Jovian66 12/26/2012 6:20:27 PM(UTC)
Amana oven smells of LP after oven is off (Oven Repair (including Ranges and Cooktops))
by m22214 11/13/2012 2:01:34 PM(UTC)
amana oven repair (Oven Repair (including Ranges and Cooktops))
by woodrow 10/16/2012 2:18:10 PM(UTC)
Amana oven won't heat properly (Oven Repair (including Ranges and Cooktops))
by azace 7/14/2012 1:24:16 PM(UTC)
Amana oven not getting hot? (Oven Repair (including Ranges and Cooktops))
by bipinsen 4/17/2012 8:40:47 AM(UTC)
Amana Oven Not Working (Oven Repair (including Ranges and Cooktops))
by brijets 12/20/2011 5:12:15 AM(UTC)
Amana Oven F9 error (Oven Repair (including Ranges and Cooktops))
by Creston 12/7/2011 5:56:40 AM(UTC)
