hi ,amana oven door latching +unlatching in self clean +showin f9 . i feel that beacause the door does lock +unlock when it shouldnt, the problem is with circuit relay board, part#ap4280300, do you agree? oh ya fellow americans, congrats on your new President ,
I would check first the door latch switches and the wire harness. The relay board is very last on the list of suspects. In case if you did not find the wiring diagram, here is the tech sheets. Gene.
Gene if door locks securely when set to clean . then after a couple of minutes it unlocks , then if you cancel +repeat clean, it locks again for a short time, wouldnt that mean that door latch switches are working?
It could be improper feedback to the control board.
please explain what improper feedback is +and if so what would i be checking
The control board reads the open or close position of these switches to determine if the door is locked, then it stops the latch motor and starts the self clean. You have to check the switches for continuity according to the wiring diagram and position of the latch cam.
i will be pulling it out tomorrow. i printed out out the tech sheets and will be checking out the switches in clean mode, will keep you informed, thanks
