rmojon1976
#1 Posted : 17 years ago
rmojon1976
i really need help with this
my refrigerator is not working but the freezer side is
i cleand all around the bootom of fridge coils everything
now the knob to adjust and set to a colder temp i dont think its working
even if i set it to high or low i dont hear anything turning on or air blowing in the refrigerator side
please help me
fixxit
#2 Posted : 17 years ago
fixxit
not sure if this is a side by side as the modle # doesn't seem to come up. however, this could be a defrost/ evap fan problem. empty out the freezer and check the evaperator by removing the evaporator cover in the back of the freezer . if it is completly iced over, it is not allowing airflow to the refer, and you have a defrost problem (defrost timer, defrost heater, or defrost bi-metal). if the evaperator fan isnt blowing (will also not allow airflow) then you may have a bad evaporator fan motor. good luck and post your results
rmojon1976
#3 Posted : 17 years ago
rmojon1976
the fan is working its a little fan under the fridge
it is a side by side unit
is the freezer cover behind the ice crushing unit ?
where is the defrost timer set ?
i know there is a temp control unit on the fridge side
but on the freezer all i find is a metal box that hold the motor for crushing ice
please advice
#4 Posted : 17 years ago
Hi
In order to provide the most accurate advise I need the complete model number of your fridge.
rmojon1976
#5 Posted : 17 years ago
rmojon1976
the model number is LSD2615HE
im sorry i wrote a z at the end of the other model number
but this one is the correct one
rmojon1976
#6 Posted : 17 years ago
rmojon1976
here are the specs
Model Number: LSD2615HE* Style: Side-by-Side w/Ice thru door
Brand: ADMIRAL Defrost: Automatic
Manufacturer: MAYTAG APPLIANCES - AMANA REFRIG. PROD. Built-in Ice Maker: Yes
Access Type: Door
Capacity and Size Measures
Fresh Food Volume: 15.83 (cu. ft.) Height: 70 (inches)
Freezer Volume: 9.77 (cu. ft.) Width: 36 (inches)
Total Volume: 25.6 (cu. ft.) Depth: 34 (inches)
Energy Efficiency
#7 Posted : 17 years ago
As per fixxit previous advise, I would recommend to check first for snow built up on the back cover inside the freezer and performance of the evaporator fan, located behind the back cover in the freezer. The fan should run when the compressor is running.
Let me know what you found.
Fridge not working, No cooling, and no display (Refrigerator & Freezer Repair)
by thepr1nter 4 years ago
fridge not working then it does (Refrigerator & Freezer Repair)
by wetweekend 4 years ago
Freezer to cold fridge not working. (Refrigerator & Freezer Repair)
by Rocky80 6 years ago
Freezer and Fridge not working (Refrigerator & Freezer Repair)
by davidj7479 7 years ago
Amana fridge not working (Refrigerator & Freezer Repair)
by mimdou 10 years ago
MAYTAG fridge not working (Refrigerator & Freezer Repair)
by Ralph Tal 10 years ago
KitchenAid bottom mount fridge not working properly (Refrigerator & Freezer Repair)
by Eldub 11 years ago
Fridge not working, freezer is. No frost, fan works (?) (Refrigerator & Freezer Repair)
by ornestreet 12 years ago
Samsung 26cf fd freezer fine, fridge not working (Refrigerator & Freezer Repair)
by ppipowerclass 12 years ago
Fridge not working and clicking (Refrigerator & Freezer Repair)
by Mbtran321 12 years ago
Whirlpool Fridge not working (Refrigerator & Freezer Repair)
by rojas5 12 years ago
GE Fridge not working, need help! (Refrigerator & Freezer Repair)
by robweber1 13 years ago
fridge not working after power out, now hot front panel (Refrigerator & Freezer Repair)
by SueV 13 years ago
Kenmore Fridge Not Working (Refrigerator & Freezer Repair)
by salenbailey 13 years ago
Freezer and fridge not working..!! (Refrigerator & Freezer Repair)
by dianaha0814 13 years ago
