monalesia253@yahoo.com
#1 Posted : Friday, January 9, 2009 1:38:37 PM(UTC)
one of the burners does not heat. I remove the element and plugged it into another socket and the element heats up fine. wondering if this could be the infinite switch and if this is something a novice could change.
misterfixall
#2 Posted : Friday, January 9, 2009 5:25:46 PM(UTC)
misterfixall
it could be switch or block that burner pushes into. are the tips of burner burned or is it damaged looking if it is replace burner with block.it still may be a switch problem
Guest (4)
cvex4370B Jenn Air Grill element does not heat up (Oven Repair (including Ranges and Cooktops))
by Guest 4/13/2021 8:44:32 AM(UTC)
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
Lower oven element does not heat (Oven Repair (including Ranges and Cooktops))
by throopwh 1/21/2015 6:26:46 PM(UTC)
Oven bake element does not heat (Oven Repair (including Ranges and Cooktops))
by crna1 7/5/2011 11:18:31 AM(UTC)
bake element does not heat up (Oven Repair (including Ranges and Cooktops))
by jrtrucks 1/18/2011 9:17:17 AM(UTC)
jenn air dual element does not heat (Oven Repair (including Ranges and Cooktops))
by ajax5777 6/28/2009 8:44:17 AM(UTC)
Surface element does not heat (Oven Repair (including Ranges and Cooktops))
by lonepalm 6/21/2009 9:30:22 AM(UTC)
new element does not heat (Oven Repair (including Ranges and Cooktops))
by NWF 9/12/2008 7:34:05 AM(UTC)
Thermal fuses and thermostat and elelment ok but element does not heat up (Dryer Repair)
by baldhippie 6/4/2008 4:12:48 PM(UTC)
Left back element does not heat (Oven Repair (including Ranges and Cooktops))
by crlowder 5/3/2008 12:47:44 PM(UTC)
