hOW CAN I TEST MY DRYER'S HEATING ELEMENT TO SEE IF IT IS DEFFICTIVE. EVERTHING WORKS BUT IT HAS NO HEAT OUTPUT. ELECTRIC SUPPLY IS OK.:mad:
You can test it for continuity, if it has continutiy them it's probably one of the thermostats. If it'sd less than a year old call a certified tech so your warranty doesn't get voided.
Nat
