I have a oven that glows red like it is working but no heat at all just wondering if anyone might know what the problem might be? Thank you
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Robin19, "I have a oven that glows red..." - Are you talking about the oven igniter glowing red? Do top burners work? Has anyone moved the range or taken anything apart recently? If the oven igniter is glowing, but the oven won't light, it's usually a good indicator that the igniter is too weak. What color is the glow? Red, yellow(ish), white? New round igniter for your Kenmore oven
I also have an oven igniter problem. They say it should glow white but mine isnt doing anything at all. It doesnt even get warm.Is it the igniter or sumthing else?
